Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop the top on my 1947 Ford Pickup
  #157 (permalink)
Old 11-18-2010, 04:56 PM
hotwheels1 hotwheels1 is offline
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Today i sanded around the rear window where i had welded then applied bondo. First sanding was done with 80 gritt and the second sanding was done with 120 gritt. Once i got it smooth around the window, i sprayed my primer coat and will start wet sanding around the cab corners and the rear window so that it doesn't look like there is a seam on the back of the cab.....then i will apply my spot putty if needed to fill any holes that may appear in the bondo.
ID:	50096   Click image for larger version
ID:	50097   Click image for larger version
