We're Always Here
We are thrilled to be a part of your project and I for one plan to continue to watch this project through to being streetable if you'll keep us posted .
Side Note
I lived in Saratoga Wyoming for nine years from Jy 85 'till Jy 94 . If you want to fly me into Denver , I'll drive up to paint it when you're ready . Just kidding , I couldn't resist . LOL
Layin mud on the back of the cab
Well here are some pics from the work i got done yesterday and today.....
Today i sanded around the rear window where i had welded then applied bondo. First sanding was done with 80 gritt and the second sanding was done with 120 gritt. Once i got it smooth around the window, i sprayed my primer coat and will start wet sanding around the cab corners and the rear window so that it doesn't look like there is a seam on the back of the cab.....then i will apply my spot putty if needed to fill any holes that may appear in the bondo.
Looking very good at this point..
It will work out a little easier... If you spot the primer without the tape.. You will blend it better...
Thanks for the heads up........much appreciated.
If you already have a DA sander, plan on stripping all the old paint with 80 grit . I wouldn't put any paint over the old original paint .
Well i have to tell ya, this is actually allot of work. I figured i could do the job in a couple of weeks, but now it's been over a month. Chopping the top wasn't the hard part, it's all the little things you have to do to make the chop look like it really isn't there. I hate to say it, but i have kind of hit a burn out point and still feel overwhelmed with the amount of stuff i have to do to finish the chop, welding, bondo, sanding, priming, sanding, painting, sanding, etc.......anyways, here are a few pics of where i am at right now.
man,that thing is lookin good.yep,it can be a bit overwhelmin at times but it is dang sure worth it!!
| TOP CHOP | Bill Corum | Body - Exterior | 3 | 08-10-2008 10:29 AM |
| Installing glass in 51 ford pickup chopped top | northportman | Body - Exterior | 2 | 08-31-2007 06:59 PM |
| 32 Ford 5W coup top | shortload | Body - Exterior | 1 | 08-12-2007 11:08 AM |
| 34 Ford Coupe Top Insert Info, Help Please.. | yekoms | Interior | 5 | 08-08-2007 07:19 PM |
| 1939 / 1940 Ford Sedan Top Chop | Sparkplug1939 | Body - Exterior | 2 | 06-19-2005 09:04 AM |
