Chop the top on my 1947 Ford Pickup - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 10-31-2010, 11:16 AM
car enthusiast
Last journal entry: Future Build: 1927 Dodge 5 window coupe
Originally Posted by deadbodyman
Another way is to "glue" your glass in with an edge moulding ,they come in many different widths and not use the big fat seal at all. The way theyre done today
Do you have any pictures of the glued in windshields? The one on this ford is a 2 piece windshield, that's why i felt the angle that i currently have in the pillar is still doable. I know too that i cut to high up into the curve, but it is a little late to recut. So i am going to make the best of this and like someone stated earlier, i will move onto other parts of the top fabrication and then move back to the windshield pillars....Since this is my first ever chop, i honestly think it isn't looking to bad and will not be perfect. With the tips i have just received on the backing plates and plug welds, i now know how i will line up the back of the cab for welding and the top of the roof. I just went and bought some little self tapping screws too, so i can pull the backing plate flush to the original metal and start my welding. Your guys help is greatly appreciated and with the knowledge i am gaining from this build, i think i may end up being a decent fabricator for these old cars.
  #77 (permalink)
Old 10-31-2010, 11:30 AM
On my first chop the windshield posts ("A pillars") needed to come out a little to fit the bottom. I pulled one side over and welded it, then when to other side to find that it was MORE off than the first one (because I had PULLED the roof over to weld the first one! ) so I tied a rope to it and out the barn window (yes I did it in a barn) and to a fence post. I had a few friends stand on the rope while I welded the post. Problem was that post had a different angle than the other! LOLOL, when the windshield (also two pieces like yours) was cut one was different than the other!!! Over the years only one person ever noticed it. But it was actually pretty easy to see if you stood in front of the truck.
But you honestly can come back and fix that corner with metal as described earlier. Remember, you are "creating" something here, you can do anything you want. Just weld metal on there until it all flows. We aren't talking about changing the "angle" of the post, just the inner portion where the glass fits.
ID:	49422   Click image for larger version
  #78 (permalink)
Old 10-31-2010, 11:41 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
My problem with being a perfectionist is that even if nobody ever noticed, it would still bother me. You don't have to settle for it being anything less than perfect . I assume you are not on a time deadline . Take your time and rework those curves last after all the rest of the welding is completed and you will have much more pride in the finished product and be glad you took the time to make it a work of art . Allan
  #79 (permalink)
Old 10-31-2010, 11:58 AM
That is the cool thing Allen you are right on the money, just a little more time and you can fix most anything. And I am not saying to leave that curve in the window opening that way, most certainly, fix it.
It has always amazed me at how nice a home hobbyist's car will be! The funny thing is a lot of home hobbyists cars are actually better than the pros do, because they take the time to make it perfect where the pro knows that most people won't see the small imperfection. The home hobbyist hasn't learn that, thinking every flaw will be seen so they make it perfect.
Believe me, I became that perfectionist too. And I can't stress enough in my experience there is VERY little between the poor job and the outstanding job other than time spent on it. The guy who has the abilities to get in there and DO it, has the same abilities to do an outstanding job in most cases.
  #80 (permalink)
Old 10-31-2010, 01:12 PM
life is a temporary assignment
the plug welds are important for strength,
Sorry!!!! but your wrong in one way.. You do not ''NEED'' to plug weld it.. for added strength.... The backing strip welded to the two upper roof top will be the added strength...To me it is a waste of time,, And just adds more heat then you need.. Put the backing strip in place, Leave a little space on your butt, Weld it right, and you ''WILL NOT HAVE ANY PROBLEMS''... You can do what you feel you need to.. But you will see what I'm talking about.. The plug welds Are ''ONLY'' to hold it into place while you are welding.. But if you have someone to hold up on it while you put a few tack's FROM THE TOP.. it will work.. When I was welding pipe for a living.. We used them inside the pipe.. They where called Chill rings. Never had to plug weld them into place... Do what you feel ''YOU NEED'' too.. Next someone will tell you that you need to flip the truck over and weld each side of the backing strap.. Give me a break..
  #81 (permalink)
Old 10-31-2010, 01:31 PM
car enthusiast
okay guys, i wasn't able to focus on anything else out in the shop other then that sharp angle i ended up with. So i have taken some time an reworked it. Let me know if this is looking better?
ID:	49424   Click image for larger version
ID:	49425   Click image for larger version
  #82 (permalink)
Old 10-31-2010, 02:45 PM
Much better..Keep pushing forward.. Your doing great..
  #83 (permalink)
Old 10-31-2010, 02:48 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Wow , what an improvement , Even I could live with that . LOL ....How about it Brian ?
  #84 (permalink)
Old 10-31-2010, 03:44 PM
LOL, ABSOLUTELY, that is what I am talking about! Just make sure both sides match so it doesn't look like my truck did.
  #85 (permalink)
Old 10-31-2010, 04:18 PM
car enthusiast
schweet guys, your opinions mean a bunch to me, so i know i am headed in the right direction. I started on the other side, but ran out of time to keep going but here are some pics.
ID:	49428   Click image for larger version
ID:	49429   Click image for larger version
  #86 (permalink)
Old 10-31-2010, 04:33 PM
You just got a big old grin out of me, YOUR top chop is looking damn good! Feels good to "create something that didn't exist yesterday" doesn't it!
  #87 (permalink)
Old 10-31-2010, 04:45 PM
car enthusiast
It sure does brian, especially when a person has a place to go to and get great information and help on doing this type of project. I was pretty concerned at first, but with all the suggestions that came forth, it is gonna be a wicked chopped top.
  #88 (permalink)
Old 10-31-2010, 07:25 PM
When I think of all the help that is available out here on the net it overwhelms me! When I chopped my truck in 1974 I was sent to a house a few towns away by a friend who knew someone who was building a truck like mine. He showed me the pictures in the 1955 Rod and Custom magazine where they chopped the dream truck. I left there with that knowledge, that was IT, that was there was.
Today I get on the net and find out how to do everything from plumbing to handling medical issues. It is absolutely amazing.
  #89 (permalink)
Old 10-31-2010, 07:33 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Not only that Brian . What about all the neat stuff available for our hot rods . Who had a clue where to find all this stuff before the internet ?
  #90 (permalink)
Old 10-31-2010, 08:03 PM
I think the thing that amazes me most are the connections you make with "odd" cars like my Rambler and Buicks. Where I had known a couple of "Buick nuts", then along came the net. OH MY GOD, I have people all over the world who own Buicks that I can chat with. My Rambler, I ask one time on the AMC forum for some radio knobs for my 1959 American and have them in my mail box a week later!
It is truly wild, never could I have dreamt of it when I was a kid trying to find parts for my Honda C110 50.
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
Installing glass in 51 ford pickup chopped top northportman Body - Exterior 2 08-31-2007 06:59 PM
32 Ford 5W coup top shortload Body - Exterior 1 08-12-2007 11:08 AM
34 Ford Coupe Top Insert Info, Help Please.. yekoms Interior 5 08-08-2007 07:19 PM
1939 / 1940 Ford Sedan Top Chop Sparkplug1939 Body - Exterior 2 06-19-2005 09:04 AM
