Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chop Top question
Old 04-11-2007, 08:58 PM
MARTINSR MARTINSR is online now
I like to cut the front post high, then when the top is off cut DOWN into the post right at the front and remove a small pie piece so the front will lean back a little and thin the top of the post to match the top piece. You will see what I am talking about when you get there. Cut find the middle of the windows and then measure out up and down half the distance you want to chop. That will put your cut out piece right in the middle.
