-   -   chopped top (http://www.hotrodders.com/forum/chopped-top-226067.html)
PRO62 11-14-2012 05:55 AM
chopped top
I have a 54 ford 2 dr wagon that has been chopped. Does any one know anybody that can recut the lexon plastic that is on the 54 to glass? Seems Calf. has most of the shops that do it and I'm in NJ.
tKS.
Tony
poncho62 11-14-2012 06:15 AM
Chances are that the reason they used lexan was that the opening wont accept a piece of original windshield, as it is out of the proper shape. Most get the windshield cut and make the opening fit that.
delawarebill 11-14-2012 08:44 AM
cut windshield
be prepared to buy a few windshields... i talk to a fella that chopped a Tbird and went through 3 before that last one didn't break..
MARTINSR 11-14-2012 09:15 AM
As Poncho said, the problem is usually the guy who chopped the top did as I did on my first curved glass chop, I chopped the top completely finishing all the body work THEN went to get the glass cut. When in reality you need to cut the roof down but before you are done get the glass cut then fit the ROOF to the glass. The shape of the glass can't be modified like the shape of the metal. I am not talking about the outer shape I am talking about the curvature of the glass where the cut is, as it curves around the corner for instance, this CAN'T be changed. So I chopped the top then went and had the glass cut and even though I cut the glass the same size as the hole, the shape of the hole was different and the glass didn't fit. At that point I could have gave up and cut a plastic windshield but instead I made a fiberglass template of the windshield and using it made the top fit the glass. The glass then fit in the stock rubber and it was done.
There are plenty of places around that cut curved glass, I don't know of any in your area but it will take a little searching be patient. But it is very likely you are going to need to do some work to the car to fit that glass in there.
