Chopped top 74 Superbeetle - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-17-2005, 05:39 PM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Need things to do.
The car that most folks have seen it the "stinkbug" owned by Fred Heldigo (sp?)
It is a killer car. Allso Walt Leatherman's "Rat Patrol" that looks like a hotrod cop car. I'll post some pictures.
  #17 (permalink)
Old 05-17-2005, 05:43 PM
PapaG's Avatar
Stinkbug.
  #18 (permalink)
Old 05-17-2005, 05:52 PM
PapaG's Avatar
Rat Patrol
6 weeks to build the rat patrol.
  #19 (permalink)
Old 05-17-2005, 07:11 PM
The black one is the one I was talking about. If you think it looks good in the photos, it was even better in person.
  #20 (permalink)
Old 05-17-2005, 09:47 PM
PapaG's Avatar
Pictures don't do it justice. Fred's stinkbug is great.
  #21 (permalink)
Old 05-20-2005, 08:12 PM
gemini86's Avatar
Hey, mine's paid for, Punk.
love the seats! very original....
  #22 (permalink)
Old 05-20-2005, 09:11 PM
PapaG's Avatar
here is one of Walt's and his son Manx's 34 Pickup. Note the VW-Porsche Engine and tranny in back.
  #23 (permalink)
Old 05-20-2005, 09:17 PM
PapaG's Avatar
This is my 68 VW type3 Squareback (station wagon). It has a 1 piece side window with a angle chop top.
  #24 (permalink)
Old 05-21-2005, 01:03 PM
Shabby chic sheet metalshaper
Check out: www.runtrod.com for an article on VW chops.
I ran a lexan windshield for years. It had margard, a coating that resists abrasion. I've seen video footage of testing where they shot a roaster chicken out of a canon at a helicoptor lexan windscreen and it did not break. It can resist bullets if thick enough. The trick is to mount it securely so it does not pop inside the vehicle when hit. A face full of safety glass is not any safer than lexan in my opinion.
John www.ghiaspecialties.com
  #25 (permalink)
Old 05-29-2005, 07:50 PM
Riot Racing's Avatar
Last journal entry: Por 15
Ahmen to that Brotha! I am thinking the same thing if i go with my chop.
How thick os Lexan did you end up using? How much did that spraying cost?
  #26 (permalink)
Old 05-30-2005, 07:27 AM
It's been years since I did that windshield....what I remember... The protective coating came on the lexan from the factory. It was pricey. I got it the same thickness as the stock windshield so I could use the stock window rubber.
  #27 (permalink)
Old 08-20-2008, 06:17 AM
The easiest way to chop a beetle roof is to idealy get a second roof. the year doesn't matter as you'll only be using sections. failing that you'd have to be pretty good with an English wheel. If you cut the roof into quarters and remove the sections of frame to drop required you'll be able to drop the sections of roof down at the corners and use a doner roof to join the sections. This will keep the natural curve and if you install an oval window in the back (you can buy these sections in both steel and fibre glass) it finishes the look off well in my opinion, and the rear window at least will be readily available.
  #28 (permalink)
Old 08-20-2008, 07:23 PM
i helped a little on one and they used 2 extra roofs
