CHP 467hp 355ci build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-17-2008, 07:33 AM
it's all subjective...
the engine is somewhere between 10.48- 10.61 depending on how much material was removed from the eye brows for valve clearance.
I would change to an RPM air gap
A tad less smaller cam maybe 5-7 degrees smaller
Go with a head with a smaller intake valve
Defenitely smaller runners, 220 is just way too big for the street but he races the engine.
The changes made would obviously bring the max hp down in the rpm range.
Otherwise, a very respectable 355 for the parts.
I DID think the cam was too big but it didn't seem too bad in the lower ranges especially with the victor jr. which was a surprise to me.
  #17 (permalink)
Old 10-17-2008, 08:20 AM
How fast is fast enough?
You nailed it with the oversized runners and too large of a cam. He's actaully loosing power because of it. The runners on a 350 should be spinning to 8k RPM with a solid roller cam with about 13:1 compression- its just too much.
Its one reason why AFR 195's work so well- smaller runner size gives you more velocity with still big flow numbers.- By going with ported Vortecs you can do a "poor man's" version.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Here's where I'm at with my 383 build Malibu73 Engine 17 12-06-2009 08:56 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
Outline to build a 32 54marko Introduce Yourself 1 07-09-2007 06:29 PM
build a moter or buy a car first? Tryin2MakeIt Engine 19 12-13-2006 09:43 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 01:48 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
