chromabase paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 04:20 PM
Bobs36ford's Avatar
Last journal entry: Bobs 36 Ford
chromabase paint
Hi Guys
When applying Chromabase..how long to wait for applying clear coat.
I'm using Chromabase/ with 50% Chromabasemaker
Old 08-12-2012, 04:29 PM
hrlys4evr's Avatar
60-66 chevy truck nut
Last journal entry: Epoxy is finally on
P-sheet calls for 15-30 minutes. I personnaly cleared at 15 minutes at 74 degrees.
Old 08-12-2012, 05:18 PM
Bobs36ford's Avatar
chromabase
Thanks for the answer. I'm glad i asked.....i thought it was 10 min.
Bob
Old 08-12-2012, 07:32 PM
35prog's Avatar
Last journal entry: More photos
you will have better luck waiting longer as the solvents that come out will cause a condition called die back. This is where the clear loses some depth. This is most critical on dark colors.
The Following User Says Thank You to 35prog For This Useful Post:
hrlys4evr (08-12-2012)
Old 08-13-2012, 04:54 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
30 minutes is the MINIMUM!!!!!
(under IDEAL conditions)
24 hrs is the maximum.
You don't want to get close to either one of those.
I wait an hour usually.
Old 08-13-2012, 11:12 AM
cyclopsblown34's Avatar
Colorsanding painter
I usually base at night, go to bed, get up, shower and spray clear in the AM. It minimizes the chance of dieback and I'm fresh so I pay more attention to how the clear is laying.
Old 08-13-2012, 12:13 PM
Irelands child's Avatar
Stick with the spec sheet that DuPont put out for Chroma paints - which is 30 minutes to 24 hours (15 minutes is too short a time). It works well that way.
If you haven't used DuPont paints, be advised that some colors will take more then the 2-3 medium coats and that is noted in their paint charts by a number. Your supplier can give you that info - assuming he even knows
Here's the DuPont Chroma Tech Manual: http://pc.dupont.com/dpc/en/US/html/...romaBaseBC.pdf (their web site is a PITA to navigate)
Old 08-13-2012, 12:37 PM
I hope your reduction is 100% because if you are reducing it 50% you are going to have some lumpy paint! It is a 1:1 ratio = 100% reduction.
chromabase paint awhellcars Body - Exterior 3 05-14-2011 12:57 PM
How to apply Chromabase paint Bobs36ford Body - Exterior 2 09-28-2010 06:16 PM
blending with chromabase 35prog Body - Exterior 1 11-16-2009 04:51 PM
Chromabase reducer Derkyb Body - Exterior 14 03-03-2009 07:28 PM
ChromaBase vs CromaPremier jimmy1 Body - Exterior 18 08-28-2007 09:59 PM
