chrome brake booster - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2009, 12:58 PM
i see a lot of these chrome brake booster /cylinder on ebay for chevys, could i make one of these fit an S10? can i just take off the back bracket and bolt this to the firewall?
Old 03-13-2009, 09:35 AM
dinger's Avatar
Moving to basics in hopes someone knows the answer. You may have to dig up some more info, as to what the boosters on ebay fit.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 03-21-2009, 09:31 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
I suspect you haven't gotten an answer, cause it's not that simple.
Boosters have to be sized for the system. Not too complicated. If it has a 9" now, another 9 inch should work, etc. The master cylinder is another story.
If yours is disc/drum, the new one needs to be disc/drum, or you get into some technical problems. Likewise the size of the wheel cylinders. There is also the issue of residual/proportioning valves in the system etc. Best bet is to get one designed for your vehicle. As far as the bolt in... unless the center hole and bolt pattern are the same, you will need to modify the firewall mount.
I assume this is a replacement, not a switch from manual to power, etc. that brings in more issues.
Brake booster troubleshooting... cefolar Suspension - Brakes - Steering 10 11-16-2009 01:02 PM
pwr brake booster issues? Dgas Suspension - Brakes - Steering 6 06-19-2007 10:20 AM
66 Chevy brake booster help? badriand Suspension - Brakes - Steering 1 06-03-2007 02:01 PM
power brake booster PaulNJ53Ford Suspension - Brakes - Steering 2 03-29-2006 07:11 PM
69 Pontiac Brake Booster Problem.. jboy Suspension - Brakes - Steering 8 07-22-2004 10:59 AM
