Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chrome trim for dash?
Old 08-01-2012, 06:05 PM
hp246's Avatar
hp246 hp246 is offline
I've used the chromed plastic edge trim. It is what it is. The more gradual the curves, the better it seems to work. On tight curves, it tends to twist just a bit, so it doesn't look uniform. If you are going to have a seam, you want to be very careful and use a new razor blade. Keep your cut as square as you can. If you are doing a truly custom ride, I'd look at some stainless steel options.
