Chroming Fiberglass - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2005, 09:49 AM
ckucia's Avatar
Chroming Fiberglass
Been flipping through the latest Summit Racing catalog. Has a gold Impala on the front cover, and a write up about it in the middle of the catalog.
Seems the front and rear bumpers have been replaced by fiberglass reproductions that have been chrome plated, according to the article.
Only detail the article gives is that this is expensive.
Anyone hear of something like this, know how the process works and know anyone who can do this sort of thing?
I've heard of plating interior parts via vacuum deposition, but I didn't think that would work on exterior parts.
Maybe this car only goes to the track on a trailer, so it doesn't need a durable coating.
Old 05-20-2005, 09:57 AM
STUPID is as STUPID does...
Vacuum Metalizing... Same process as you mentioned and I don't think it would live for very long on the street...
Mark
Old 05-20-2005, 02:22 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Mark
Electroplating plastic (and even leather! - ever see a pair of copper plated baby shoes?) has been going on for nearly a century. All chrome on the front of new cars is electroplated chrome over ABS plastic. Haven't you seen a Chevy pickup with the chrome peeling off its chromed grille and exposing the gray plastic underneath? Incidentally, that same pickup probably had the clear coat peeling off too. GM is in TROUBLE!
The process requires painting the non-metallic part with a conductive paint. It is usually a clear lacquer base that is filled with bronze or silver powder. Once this is dry, the surface is conductive and the part is copper/nickle/chrome plated just as it would be if it were metal.
Yet another question about bonding fiberglass to metal Psionic Body - Exterior 37 01-17-2010 08:03 AM
How Do You Make Things With Fiberglass? Silentlion_69 Body - Exterior 11 01-01-2006 08:05 AM
Wrinkled fiberglass Psionic Body - Exterior 61 11-25-2004 10:13 PM
Fiberglass help for novice tyman00 Body - Exterior 1 10-20-2004 12:36 AM
Need Information on fiberglass thicknesses Psionic Body - Exterior 7 12-25-2003 05:49 PM
