Chromoclear G2-4700S - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2003, 06:49 PM
Post Chromoclear G2-4700S
Anybody had trouble with this? I painted my 30 coupe chromobase red then used G2-4700S activated with G2-4507S used no reducer like my supplier said to do, wet sanded, buffed, shine is good BUT there is areas that look like the clear blushed or fogged, any ideas how to correct or what happened? Always used V-7500S clear with real good results supplier said this would do better, yea right, Thank You <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 05-24-2003, 07:53 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Post
Iv`e used that system a lot and never had any problems. It stays soft for several days, and sands easy if not fully cured. Sounds like maybe you went through the clear, it`s easy to do.
Old 05-25-2003, 04:41 AM
Post
[quote]Originally posted by troy-curt:
<strong>Iv`e used that system a lot and never had any problems. It stays soft for several days, and sands easy if not fully cured. Sounds like maybe you went through the clear, it`s easy to do.</strong><hr></blockquote>
Thanks, I guess anything is possible but I`m sure I didn`t go through, thought maybe I didn`t go deep enough. thanks for the input
Old 05-25-2003, 07:19 AM
troy-curt's Avatar
Post
Smooth is as deep as you need to go, or just remove the new look.
Old 05-25-2003, 09:40 AM
Post
thanks again
