chrysler 3.0 no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2010, 08:55 AM
ok so its a Chrysler 3.0 in a 97 minivan was driving down the road and it shut down after a little poking around im not getting any spark any ideas
Old 12-01-2010, 05:28 PM
bigdog7373's Avatar
Of course it's fast
What kind of ignition system is on it? Distributor or computer controlled?
Old 12-01-2010, 05:30 PM
distributor
Old 12-01-2010, 05:33 PM
bigdog7373's Avatar
Of course it's fast
Start with the basic stuff. Pull off the cap and see if there's anything visibly wrong, like excessive build up, worn rotor or terminals. Get the coil tested at autozone or whatever you have near you.
Old 12-01-2010, 05:46 PM
Any check engine light? Turn the key to the first position (accessory position) then cycle the key three times to the on/start position on the third time leave it in the start position (do not start) and record how many flashes you see from your check engine light. two sets of 5 flashes (55) means there are no problems.
Old 12-01-2010, 05:48 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Could be a coil pack/ or might have a striped timing belt. JMO How does the engine turn over ? Did this happen all the sudden ?
Cole
Old 12-01-2010, 05:50 PM
sounds normal turning over but it could have jumped a few teeth it does have 230K on it but at the same time no spark at all from the plugs i checked but yep all the sudden just cruising at 60 and it just shut off no signs just gone
Old 12-01-2010, 05:52 PM
It would have set a light if it jumped timing!
Old 12-01-2010, 05:55 PM
i thought of melted wires iv had that problem before on another car but i cant find anything the wires are all still warped in the flex tubing they came on from factory
Old 12-01-2010, 05:57 PM
eloc431962's Avatar
Wiki Edits: 37
Not alway's not everytime, I have seen it before and did not throw any lights/codes.JMO
Cole
Old 12-01-2010, 06:04 PM
eloc431962's Avatar
Wiki Edits: 37
I will tell you something else , If you strip enough teeth of the belt you won't have any fire/spark.
Cole
Old 12-01-2010, 06:10 PM
if it was still light out id pull the inspection cover on the timing belt
Old 12-01-2010, 06:19 PM
bigdog7373's Avatar
Of course it's fast
I don't like to correct the way people speak but this one has bothered me to the max for all my life. It's not "all of the sudden". It's "all of A sudden".
Now, back to the subject. When is the last time the timing belt was replaced? I don't trust belts for timing. There is a good chance that it jumped or stripped some teeth like the rest of the guys said. That would be the first place to check, then check the ignition system if the belt is ok.
Old 12-01-2010, 07:07 PM
eloc431962's Avatar
Wiki Edits: 37
Then don't.
Cole
Old 12-01-2010, 07:32 PM
never my grandma bought the van new and have it to me when it hit about 160K gave it to me just basic repairs when something broke the timing belt may be completely broke i haven't checked
chrysler 383 spark plug question adam83 Engine 4 04-26-2010 08:56 PM
96 chrysler 3.0 oil pump removal fast68 Engine 0 03-06-2010 02:59 PM
2006 chrysler 2.4L no spark after engine swap fast68 Engine 0 10-10-2009 02:25 PM
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
3.0 taurus with intermittent spark fumplet Engine 0 03-04-2006 09:10 PM
