Chrysler 318 rebuild in Dodge RAM W150
Hi,
Im going to rebuild my 88's engine and transmission. Im not looking for too much of an performance upgrade but like to get ur opinion. Im looking to build a stock motor with a rebuild kit from summit (Part# MHP152-322). Comes with sealed power cast aluminum pistons (Part#Z285AP30) that would bring compression to around 9:1. I like to open up the valves to 2.02 intake and 1.60 exhaust and run Comp cam part#20-220-3 with grind XE250H. I believe that would work nice in a 4500 pound truck that I like to use as a daily driver and to pull trailers. As you can see this will be a budget built and Im aware that the performance will be limited. Now, do you think that will work or is there better combos for similar cash? Will it make sense to use bigger valves or is that not helping much? Also since this is a 88 engine it comes with the TBI fuel system. Im debating if I should convert to a carb or if it would not be worth the effort. Did anybody do that already? What is all involved? And if I go carb what manifold would be good? Any help will be greatly appreciated! Tom |
A magnum head swap is very effective. You get better chambers, the 1.92 valves, and they bolt on. Mopar makes the pushrods needed for the conversion.
The 340 hp mopar performance cam .430/.443 lift, is great for a driven vehicle. |
No , they dont.
318 heads are terrible. |
Whats needed for a magnum swap.
Magnum Head Assembly MP# P5007086 (two required) Magnum rockers, stands, guide plate, and bolts: MP# P4876050 (eight required) Special length Pushrods: MP# P5007477 Mopar/AMC lifters: Comp Cams #822 or MP4529220 Magnum head bolts: MP# P4876759 Magnum valve covers (desirable, maybe not required) MP Magnum intake OR Modified LA intake OR Bushed and re-drilled heads (to adapt LA intake) Spark plugs for Magnum heads - I used Autolite #3923 Standard LA gaskets Throttle cable bracket from MP (only used with vertical drilled intakes)MP# P4876850 Throttle return spring bracket from MP (only used with vertical drilled intakes): MP# P4876313 Some mopar heads info The 675 is a small 318 head Not closed chamber.. The 587 heads are the 340/360 heads used in 1973/74 up through in some cases 1976. Most OEM 915/587/596/974 CC'd in the area of 72 CC's. None of the above heads are closed chamber heads. -302's are closed chambered sbc heads. 051's ase closed chamber. Both are poor performers. Might flow 170cfm intake. 323LA RPM type intake and 340hp cam, mopar 360 magnum head swap made 237rwhp at 6100rpm, and 4000rpm 319lb/ft of max torque. Before magnum head swap had 278lb/ft of torque at the same 4000rpm, and 211hp at max 5800rpm with 318 port 051 Heart shaped LA heads. |
common 318/two-barrel valve sizes of 1.78/1.50-inch and in stock trim flow about 135 cfm stock on the intake side
The fully ported heads with larger valves installed showed an intake flow improvement of nearly 60 percent to a respectable 215 cfm at a peak of 0.500 lift. Its a stretch but the heads "can" be modified. not sure its worth it if you pay someone for the porting... |
Which mopar performance porting template did you use as a port guide? Not one set of templates will flow those numbers on a 2 bbl 318 675 head.
Thanks for all the great informations!
As much as i would like to upgrade the entire head i most likely will stick with my 318 heads. Since i need new valves anyway i think i can go bigger. So what about the TBI or carb option? Does anyboy know if the TBI is capable to deliver the fuel for my mini upgrade? How about tuning that all in? just keep all the information coming! Thanks again. Tomi |
TBI systems can provide a benefit. However if your altering the base engine with larger valves and such, a carb is so dynamic and freindly. I would chose a edelbrock AVS or afb around 600-650 cfm. The AFB/AVS is easy to tune, rebuild, and very staight forward. The intake for pulling would stick with the performer 318 to keep continuity of the small head runners. It will stimulate the low end for pulling and towing.
Good luck. If you want more on the Magnum swap look into Moparts.com, and make this post. You can get a pair of magnums around $179. |
| 1988 Dodge ram 318 fuel injection to carb converstion | Hobodave | Hotrodding Basics | 5 | 11-02-2012 04:45 AM |
| 318 5.2 V8 Dodge Ram 1996 | PM123 | Engine | 2 | 09-30-2011 11:40 AM |
| 1988 chrysler 318 | brian berwick | Engine | 1 | 12-23-2007 10:56 AM |
| Holley two barrel on a chrysler 318 problem | powerwagon | Engine | 2 | 10-09-2003 08:42 PM |
| '96 Dodge Ram tranny rebuild kit | antirice | Transmission - Rearend | 6 | 04-22-2003 06:19 PM |
