chrysler 400 misfiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2013, 03:49 PM
adam83's Avatar
I have a 72 newport, 400 engine 2 barrel carb, single exhaust. The engine would randomly misfire, shake and shudder under anything but light acceleration. Sometimes I would have to tap the pedal repeadetly to keep it from dying either from to much rpm or to little. The problem magically went away, then came back. I put new points on it and the problem was gone again, then it came back. Yesterday I put autolite 85 spark plugs in it and it didn't help. It has new cap, rotor, points and spark plugs. The wires looked fine. Some of the old plugs I took out were powdery white like it was running lean, but not all of them, some looked ok and maybe a little oily. Does this sound like detenation or misfire? What should I check next?
Old 05-29-2013, 05:14 PM
Fuel system blocked or dirty.
Old 05-29-2013, 10:10 PM
33Willys77's Avatar
Could be a coil issue too, but also check out the carb/fuel system (plugged tank, filter, pump, fittings/lines, carb)
Old 05-29-2013, 11:57 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I know you just installed new plugs but you really need to install the Platinum plugs if the motor has alot of miles on it. I'm a firm believer in the Platinum plug for high mileage motors because I own a few of them.
Chrysler 400 BB questions BigRoy1978 Hotrodding Basics 7 02-20-2012 10:16 AM
Chrysler 400 Vs. 440 into "A" Body Newf Wit a 440 Engine 7 01-20-2012 09:43 PM
Chrysler 400 BB help please dj_xtreme Engine 2 09-23-2003 11:26 AM
Chrysler 400 BIG BLOCK dj_xtreme Engine 0 09-16-2003 03:46 PM
Chrysler 383 vrs 400 tm454 Engine 2 02-03-2003 10:52 AM
