Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chrysler 400 Vs. 440 into "A" Body
Old 01-19-2012, 04:19 PM
Centerline Centerline is offline
Wiki Edits: 49
It will ultimately cost you less to just do the 440. As far as installing it in your "A" body you'll need to go HERE to pick up the correct motor mounts etc.
Centerline
HotRodsAndHemis.com
"Running a small block Chevy is like having a girlfriend who wears a push-up bra. The numbers look great, but once you get under the hood, there's not as much there as you thought." - Anonymous
