Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chrysler 42LE transmission
Old 05-08-2011, 07:22 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by spanky36
The car has 89,000 miles the fluid looks good and smells good. Only recent service was a oil change. Never had any problems, disconnect battery to clear code and check engine lite. Shifts ok to 2nd misses 3rd then check engine lite and locks in 1st.
it should be 2nd gear as that is "limp" mode on that trans. the fluid can be cherry and still have an internal problem, as its a mechanical part that has failed, not the electronics. the reason the code is thrown is because the info from the input and output speed sensors are not matching what they should for the programming of the TCM.
