what is the make and model. You may have a harness connector up near the firewall that you can do a pinout test for the solenoids.
I Checked one in a jeep a little while back and I was able to ohm it at a breakout connector at the firewall . Never had to crawl under. Most of the coils are 1.1 ohms. Seems one is a different value ( i think it was the lockup solenoid) I had one solenoid come in at .7-.8 ohms it was the culprit. Changed the pack in the trans in about an hour and a half.Works perfect again. Post your make and model with engine size and I will put up some info for you. |
the P0733 DTC is a gear ratio error code. that means that the TCM is commanding the shift and the solenoid block is trying to make the shift. usually when a solenoid block has an issue, it will throw a circuit or solenoid performance code. how is the condition of the fluid? how many miles are on the car? any recent service work done recently? |
The car has 89,000 miles the fluid looks good and smells good. Only recent service was a oil change. Never had any problems, disconnect battery to clear code and check engine lite. Shifts ok to 2nd misses 3rd then check engine lite and locks in 1st.
| Finding a V8 Chrysler engine and transmission for a"48" Plymouth Business Coupe? | flathead218 | Hotrodding Basics | 27 | 02-18-2011 03:56 PM |
| Chrysler NAG1 Transmission Question | 33 Plymouth Coupe | Transmission - Rearend | 1 | 01-18-2011 01:21 PM |
| Finding a V8 Chrysler engine and transmission for a"48" Plymouth Business Coupe? | flathead218 | Transmission - Rearend | 2 | 04-24-2009 05:59 PM |
| Missing transmission,carb linkage..63 Chrysler 300 Automatic | Mush | Transmission - Rearend | 4 | 06-27-2008 09:11 PM |
| Finding a Chrysler engine and transmission for a"48" Plymouth Business Coupe? | flathead218 | Hotrodders' Lounge | 0 | 04-27-2002 01:56 PM |
