chrysler-904 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 04:40 AM
chrysler-904
i replaced pump in trans when reinstalled the truck does not move. it trys to move forward but acts like the brake are locked up does this in all possitions any help would be appreiciated thanx
Old 07-04-2007, 08:15 AM
hard to say without tests but a possibility could be stuck valve in valve body or two gears ingaged at the same time. maybe park paul locked in the notch
Old 07-04-2007, 11:34 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
my questions start with;
why was the pump replaced?
was the tranny functioning correctly before the pump replacement?
Does the tranny act like it is in gear while the shifter is in Park & Neutral also?
post back when you have a chance
Old 07-04-2007, 11:51 AM
chrysler-904
the pump was replaced because bushing bad due to loose converter to flexplate bolts loose. the trans does this all positions. p r n d 1 2. was working properly except for leak before pump replacement
Old 07-04-2007, 12:13 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
OK..... did you match the pump up properly for design?
Some input shafts have 2 sealing rings , some are 3 sealing rings. Pump stator & input shaft designs must match
A mismatch would cause troubles..... either way , I believe you need to remove the trans to diagnose & fix the problem
Any Old Chrysler guys out there? vintageautoparts Hotrodders' Lounge 7 02-21-2007 07:36 AM
chrysler 904 studebaker46 Transmission - Rearend 3 11-04-2006 03:49 PM
Chrysler Imperial lower control arm interchange powerrodsmike Suspension - Brakes - Steering 14 08-05-2006 06:08 PM
Need help on chrysler brakes imperial Suspension - Brakes - Steering 1 03-05-2006 09:41 AM
What is wrong with a chrysler 68newport383 Body - Exterior 23 02-11-2003 04:35 AM
