Chrysler/Dodge Paint Procedure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 10:55 AM
I am refinishing a tailgate for a customer off a 2001 Dodge Ram 2500 3/4 ton. He gave me a touch up rattle can the previous owner had from the dealer (it was branded Mopar). The paint code is ZDR. I did a little bit of research and the paint codes for that truck/year that match is PDR. The guy at the paint shop said that the DR is what matters. My first question is that a correct statement? I don't doubt it is but I just wanted to ask since I was posting.
The primary question I have is that I found a deciphering of the Body Code Plate from Geno's garage (Dodge pickup Body Tag Decoding) and my primary question is regarding section 14 of the body code plate. Section 14 is the Paint Process. When I look at the description it just says "Open Space". What are the possible codes for the Paint Process? I'm assuming it would describe whether it was single, double, or even a tri coat paint job or maybe even the type of paint that was used. If anyone could help with what those possible Paint Processes would be I'd be grateful. I obviously want to duplicate the process of the original and not just assume it was BC/CC. Especially since the color is a metallic.
Chrysler 318 rebuild in Dodge RAM W150 Furytom Engine 11 01-12-2014 07:20 PM
Desoto, Chrysler, Dodge Hemi parts interchange moparjoe Engine 8 12-20-2010 08:59 AM
1937 Chrysler, Dodge and Plymouth interchange Footstomper Body - Exterior 0 04-05-2007 09:48 AM
Paint procedure 39chevy Body - Exterior 2 09-15-2003 03:49 AM
parts wanted for mopar, chrysler, dodge, plymouth cr250r_86 Engine 0 11-11-2002 07:16 AM
