From a ingnition stand point, looks like a HEI distributor to me without the top cover. Where is the top cover?
Do you have at least 12-13 volts at the HEI BATT terminal at all times when the thing is running? Test by putting positive lead of a DC volt meter on the BATT terminal of the HEI and then negative lead to ground or battery negative terminal when the engine is running, the HEI needs at least 12-13 V at all times when the engine is running. Check for good engine to chassis to battery negative ground, the HEI needs a good ground. Battery in the trunk of the Avanti? The module in the HEI can be POS and it dies when heated up, rotor button inside the cap, bad pickup etc here is some good info: Testing HEI Coil/Module HEI Modules |
I think there's crud in the tank that was blocking the fuel pickup filter (sock). As time goes by, this may happen again. Replace the "sock" and I think you'll be good.
PatM |
| engine chugs at constant speed | biggus | Engine | 10 | 06-22-2010 05:48 PM |
| Car cough's and chugs when coming to a stop | my oldcar | Hotrodding Basics | 9 | 01-16-2010 10:20 PM |
| 91 oldsmobile with a 3.8 chugs | fumplet | Engine | 2 | 08-14-2006 01:59 PM |
| dies on me | Caesar_Mikey | Engine | 2 | 05-21-2005 01:21 PM |
| Engine just dies | Siggy_Freud | Engine | 6 | 04-29-2005 11:51 AM |
