Cilynder heads for my 406 camshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2013, 01:08 PM
Location: Riviere-du-Loup, province of Quebec in Canada
Hi! every body. Once again, Excuse me my poor english.
I'm building a 406 and have finally chosen this following cam for my interest:
Lunati 10120410
RPM Range: 2000 - 6000
Lift with 1.5 Rocker: .480"/.480" .512"/.512" with 1.6
Duration @ .050": 230/230
Advertised Duration: 292/292
112/106: 109/107
In a magazine, they use an AFR 180 with 1.6 rockers. Is the AFR 195 could be better? I already have a Brodix HP1 brand new in box and was asking myself if the matched IK200 or IK 180 would be nice too because, there is a difference in flow numbers. What do you think about it?
My 406 will have the same setup with 22 dish.
(Impersonator II)
Chevrolet 406 CI Engine Build - Chevy High Performance
Thanks
Old 02-28-2013, 01:09 PM
vinniekq2's Avatar
very very nice heads=good
cheapo hydraulic flat tappet cam=why?
buy a roller cam
Old 02-28-2013, 01:25 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I'm using a cam similar to the one he is using. It's a Comp Cam 280 HFT on my 406 sbc and 76CC 227AFR Heads. 512 lift with 1.6 roller rockers, 11:1 Power Forge pistons. With 410 gears and 3500 stall converter on a TH350 It takes off like a jack rabbit. Snaps my neck fast right off idle. Nice lope idle, and If not careful with the gas pedal I smoke the tires.
The Following User Says Thank You to lg1969 For This Useful Post:
Coolrider (02-28-2013)
Old 02-28-2013, 01:45 PM
vinniekq2's Avatar
cam choice
anytime an engine is under cammed it will perform very well at low rpm.how much power did you leave on the table with AFR heads and a flat tappet cam?
Old 02-28-2013, 01:48 PM
lg1969's Avatar
All the way up too 6500 RPM.
Old 02-28-2013, 02:10 PM
lg1969's Avatar
As far as I'm concern, I'm happy with the set up.
Old 02-28-2013, 03:09 PM
vinniekq2's Avatar
small cam
for most people,smaller is better.If you have what you want,its the correct cam,,,,"for you"
Old 02-28-2013, 08:14 PM
buy a roller cam
I've been also interested by the comp cam Magnum 280HR (12-430-8)
Old 02-28-2013, 08:19 PM
I know. They have exactly the same specs. you seem really satisfied. Good for me to know that.
Old 02-28-2013, 08:26 PM
Originally Posted by F-BIRD'88 View Post
You wil make a lot more power by using a better cam. And use the 195cc AFR's or the 200cc port IK-200's on your 406.
They are both great choices and just right for your 406.
A solid or solid roller will make a ton more power. A hyd like the Comp XE284H-10 will make a lot more power than the little 230deg cam.
For a solid flat tappet I'd use a Isky 201534 Or a Crane F-244/3454-2S-6
ISKY Racing Cams - Do It Right. Race with the Legend. Camshafts, Connecting Rods, Valve Springs, Lifters
Crane Cams | Automotive Home Page
For a solid street roller Id look at the Comp cams Xr286R-10 12-772-8
COMP Cams - Performance Camshafts, Lifters, Valve Springs, Rocker Arms
The Lunati Solid VooDoo solid street roller (of equal .050" duration) is another good choice for your 406.
Lunati Cams, Cranks, Pistons, and Rods - Lunati Power
all of these are more powerfull than the cam used in the Impersonator 406 article.
Its a baby cam.
Very interesting. you help me a lot with your knowledge. So, i think to go with the Brodix IK 200 and take an interesting look on your suggestions.
Old 02-28-2013, 08:28 PM
vinniekq2's Avatar
you will be further ahead with a roller cam,for sure
enjoy the build
The Following User Says Thank You to vinniekq2 For This Useful Post:
Camshaft for a 406 engine ? ZEX750 Hotrodding Basics 1 07-27-2012 03:59 AM
What CAMSHAFT use for a 406 SB Chevy? Killerhap515 Engine 41 05-19-2011 05:31 PM
pitting on cilynder wall J boy Engine 5 02-07-2010 12:49 AM
406 Camshaft mesterious Engine 6 12-27-2009 01:56 AM
406 heads Red_89gt Engine 10 08-09-2009 09:03 PM
