C'ing frame - dangerous???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 08:17 AM
reflog's Avatar
I read a couple of articles that indicate C'ing the frame at the rear axle is dangerous because it weakens the frame in that area. Is this a fact? I was thinking of doing because the rear axle has to much movement and hits the frame when I go over a bump or hit any type of hole in the road. I was thinking I would box in the rear area after putting the C's in but now I am not sure what to do. In a light 32 3wdw like I have I wouldn't think that the C'd section would be that weak that I would have to worry about it bending or breaking. Any thoughts?????
Old 06-08-2011, 08:36 AM
Any radical change in the shape of the frame rails is a stress concentration, so yes, all else being equal, C'ing the frame will introduce a potential weakness. Now, strength can be restored by throwing metal at the problem (boxing plates, stiffeners, etc). It's certainly possible to do this right, but it's also possible to do it wrong.
Old 06-08-2011, 10:33 AM
life is a temporary assignment
There is a right way and wrong way of doing everything... If you do it right from the beginning, You won't have any problems...
Old 06-08-2011, 10:44 AM
A stock frame (truck, right?) is made for hauling loads. A half ton is rated to haul a load. A notched frame just needs to hold its own weight as well as body with strength for safety. If you were to C it and still want to tow a mobile home, you can see the potential for troubles. If done properly and used in the cruiser manner intended I can't see it being a problem at all. So, even if it's weakened, consider what it'll be used for and don't worry about it. It just won't be a work horse anymore.
Old 06-08-2011, 11:17 AM
This is a stock, original 32 frame ( minus the cross members )
And here is the same frame boxed and with a " C " section
You KNOW that the frame ( boxed ) with the " C " section is considerably stronger than the original flimsy frame
Because you are doing some work on a 32 chassis, you might find my 32 project journal interesting.
Go here http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Old 06-08-2011, 11:46 AM
AntnyL's Avatar
If you're running parallel leaf springs to suspend your rear axle, you need to make sure the C-notch is boxed and strengthened adequately to avoid folding up the frame. If you're running coils/coil-over shocks mounted fore of the C-notch (in front of the axle), the issue isn't nearly as great since the frame will load up ahead of the C notch.
Old 06-08-2011, 12:26 PM
Irelands child's Avatar
If you are at all concerned, then just make up 10ga or so doubler plates to weld to the inside of the frame along the boxing plates. Extend them a couple of inches beyond the 'C', each side. I would also, again only if worried about strength, drill some half inch holes and weld through them as well as the perimeter. It's overkill, but................
Irelands child
Another dangerous new car to see in the news? MARTINSR Off-Topic 4 07-25-2008 01:32 PM
Map of strange and dangerous happenings currently happening Bad Rat Off-Topic 11 11-09-2007 05:30 AM
Dangerous Car Drifting Video gabet Hotrodders' Lounge 12 01-08-2006 11:05 PM
More dangerous stuff on CCR TV Centerline Hotrodders' Lounge 22 10-29-2004 08:41 AM
Dangerous Jobs dollybud Hotrodders' Lounge 7 10-16-2003 12:27 AM
