CJ2A transfer case spline leaking - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 03:12 PM
47 Coupe's Avatar
46 model CJ2A transfer case output leaking past the splines. I replace the seal and took care of that leak, but now its dripping from the spline. Any ideas?
Thanks
Old 06-03-2011, 05:51 PM
leakin splines
take the yoke back off and use sealer on the splines, clean yoke and splines well before applying sealer and I like the ultra gray sealer , you can get it any decent parts store. good luck Andy
Old 06-03-2011, 07:24 PM
47 Coupe's Avatar
Is that like an RTV sealant?
Old 06-03-2011, 07:32 PM
sealer
Yes it is good luck again, Andy
np 203 transfer case tgbulger2 Transmission - Rearend 1 02-12-2011 09:24 PM
leaking transfer case tommy evans Transmission - Rearend 7 07-27-2010 05:18 AM
Transfer case - NP 203 - 205 scook Transmission - Rearend 3 01-09-2010 11:28 PM
Transfer case - NP 203 to 205 d&c repairs it all Transmission - Rearend 3 03-08-2009 10:29 PM
transfer case dbarnes Transmission - Rearend 2 09-16-2005 07:26 PM
