clacking sound until engine warms up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2005, 08:12 PM
I searched the forums and found that it sounds like the clacking sound my 357 makes is a bad lifter or two..., but does this sound generally quite down after the engine warms up? B/c my engine only makes the sound at idle for a little while, but once I take it out and jsut drive it around the block and park it, the sound seems to go away. I was jsut wandering if a bad lifter will quite down liek this, and should I try that lucas stabalizer? The thing that sucks is I just built this motor and it has less than 1,000 miles on it, and it was also the first engine I've built top to bottom by myslef.
Old 05-13-2005, 08:36 PM
It sounds like a bad lifter all right. If you can narrow it down to which bank you can pull that valve cover. With the engine cold try to push down the rocker on the cam lobe side. You shouldnt be able to move it. If you have a bad lifter it will probably move.
Old 05-13-2005, 08:41 PM
another thing is they are hydraulic lifters, when i push down on the rocker above the pushrod, won't the rocker and pushrod move anyways since they are hydraulic lifters?
Old 05-13-2005, 09:31 PM
Bumpstick's Avatar
Hammer and a torch
Did you build it with forged pistons...?
Old 05-13-2005, 09:40 PM
the lifter should have oil in it and you wont be able to move it unless its bad.
Old 05-13-2005, 10:04 PM
lluciano77's Avatar
It sounds like piston slap possibly caused by a collapsed piston skirt. I hope I am wrong. When the engine warms up the excessive clearance between the skirt and the cylinder wall get tighter. That is why the noise gets quieter.
The way to check is to pull one spark plug wire at a time. Only pull one wire at a time and see if removing one makes the sound go away. Obviously the one that quiets it down is where the problem is.
Piston slap will be the worst when the engine is cold. You will hear it when the car is just coming out of idle, and under load.
Old 05-14-2005, 10:28 PM
I only here this nosie at idle, I don't hear it at all when I rev it gradually, fast, under load, or anything jsut at idle, and it also is only loud enough where you can here it if you're under the hood, so it's not horribly loud. I'm leaning toward a bad lifter and will try what 454me said, I just haven't had time yet.
Old 05-14-2005, 11:13 PM
lluciano77's Avatar
The fast bleed lifters will be able to be pushed by hand.
Just because I am one strong mother... I can sometimes compress stock springs down and open the valve by hand. It can be hard to tell which way you are getting movement when doing this. It could be the valve, or it could be at the lifter. You have to look closely.
Old 05-15-2005, 05:01 AM
GoneNova/406's Avatar
brand new roller rockers also do that.could that possibly be it.try putting some mystery oil in it.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Carburator Terrano Engine 10 08-07-2004 11:22 AM
How does this engine combo sound? Dubz Engine 11 10-26-2003 07:13 PM
Investigating Strange Engine Sound horvath Engine 15 07-15-2003 09:56 AM
How's this engine combo sound. 70 nova Engine 11 07-09-2003 09:06 PM
