Clausen ALL-U-NEED Primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2007, 05:30 AM
Silverback's Avatar
Boost Retard
Has anyone used this stuff? After considering it claims to replace etching, epoxy, 2K primers and sealer, is water and solvent proof when dry and isocyanate free, sticks to everything… seems too good to be true.
Looking at the application guide:
http://www.smartshoppersinc.com/auto...ausenHelp.html
The biggest hassle that I see is that I don’t have a gun tip as big as they recommend
Old 03-23-2007, 08:33 AM
IMO, too good to be true. When you boil it down its still a poly primer, its body filler.
Ill spend the extra hundred bucks and apply some epoxy first to that bare metal and have something with a track record.
Old 03-23-2007, 06:55 PM
Custom builder and painter
Last journal entry: Another test fit of the axle
It's very similar to the Z-Chrome rust defender. Good stuff, and known of people using only that as a primer but I still like to epoxy first.. use the poly primer then epoxy, then 2k..
Clausen's products are top notch, and I really like thier polyprimer's but I still like something over them.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Having problem with epoxy primer...... onebadmerc Body - Exterior 22 05-19-2011 02:31 PM
PPG K36 primer w/ purple gun BIGSKY Body - Exterior 16 11-20-2006 01:12 PM
Primer Questions & observations x711 Body - Exterior 1 01-19-2006 10:23 PM
good primer over ok primer hoss Body - Exterior 1 09-17-2003 02:28 AM
