Clay Bar - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2006, 10:39 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Clay Bar
OK, give me your opinion, do these clay bars have a place in my paint
supplies???.
A friend showed me one by "Adams" and I was impressesd.
It removed overspray and contaminates from a shiney black
finish without any scratches.
Do you guys use these for anything?
Old 04-13-2006, 11:08 AM
run your hand lightly over the roof.....feels anything like sandpaper....then absolutely yes
very effective, very fast, and very easy......very wet and don't rub, just a light rub (like you were using "Pledge" on a table?) and constantly keep kneeding it like bread dough it to have a new clay surface on the paint
you can do the hood/fender tops/roof/trunk in less than an hour (?), very good chance it will feel like a babies butt when done
one bar can do 5+ (?) cars cause you keep kneeding it
(and yes even if just to test cause "Plan B" is cut and buff)
Old 04-13-2006, 11:37 AM
astroracer's Avatar
This is an absolute must have in my detailing box! I was skeptical myself until I used one for the first time. Incredible difference on a previously well maintained newer paint job. Try it on your windshield before using Rain-X!
Mark
Old 04-13-2006, 11:42 AM
BarryK's Avatar
JC,
This is the best money you will ever spend.
I have done many cars over the years with the same clay bar, one had bedliner overspray and it took a total of 20-30 minutes to do the whole car.
A word of caution, if the clay bar drops on ground, you must throw away.
Bridge paint overspray off another You just cannot beat them.
I will say this, each company makes a solution spray ($4-9 qt) to go with their clay bar and JC as tight as you are I'm sure you will use water but if you do your being penny wise and dollar stupid. It will work and you know what your time is worth, so thats up to you.
Old 04-13-2006, 12:48 PM
good point Barry,
DEFINITELY store it in a good zip lock bag or screw top jar...and a 16oz spray bottle of Mother's Showtime (or similar) does 5+ (?) cars.... "if".... you can resist using it to remove fingerprints etc
Old 04-13-2006, 01:05 PM
jcclark's Avatar
The Penny Pincher
Thanks guys.
Barry, if it cuts time then even I'm willing to pay for it
(I learned that lesson a long time ago with sandpaper.)
I'm cheap, not stupid. Well most times anyway.
Old 04-13-2006, 03:14 PM
Or endust for you jim.
I've used them before in the shop too when we got in a cars with overspray, being too close when they were painting a house or something like that. We would usually run over with the clay bar then hit with a buffer.They work good. I don't use them often, but they defignatly have their place.
Old 04-13-2006, 03:33 PM
OK Kenseth....I'll bite.....why is it endust for Jim.... I don't get it
Old 04-13-2006, 06:32 PM
The endust comment is from one of jim's tips.
Do you wet the floor before painting?
He also was known "the electric blanket guy" and that was under his avater for awhile, but that has since changed to bondokings step dad. Guess I spend a little too much time on this forum.
Old 04-13-2006, 07:24 PM
thanks Kenseth.....maybe in 3 months "tack rag" would have popped into my head....
Had to chuckle at the "do you wet the floor"....
In Florida you ask: "has your floor (and walls and ceiling) ever gotten dry?"
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Sway Bar Bushings - Distorted? 66GMC Suspension - Brakes - Steering 4 01-30-2006 08:07 AM
65 Belair Sway bar question sabino56 Suspension - Brakes - Steering 11 12-26-2005 08:22 PM
Clay bar hints/tricks??? Toyman Body - Exterior 1 08-22-2005 12:18 PM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 07:10 AM
