Clay bar hints/tricks??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2005, 12:28 PM
Toyman's Avatar
Does anyone have experience using a clay bar to remove overspray? I got a little overspray on my car when painting the engine compartment and bought Mothers clay bar system. I tried it yesterday after washing the car, and it seems to be working, but it also seems like it's going to take forever. Any hints or tips??
Old 08-22-2005, 01:18 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
You may need to use something a little more abrasive if
you have a lot to do. I like the 4000 grit foam pads
for a DA sander you can use with water, also you can use
sandpaper up to 3000 grit. You'll have to experiment and
see what works best for you, start out with the finest grit
you can, the finer you use the less buffing.
I wouldn't go any more coarse than 2000 grit myself.
Question On putting in a tri 4 bar on a 50 creativeinteriors Suspension - Brakes - Steering 1 07-22-2005 11:21 PM
4 Bar que. 39chevy General Rodding Tech 3 10-18-2004 06:21 PM
Panhard bar revision 5window Suspension - Brakes - Steering 2 11-06-2003 05:31 AM
front sway bar mount location fire power Suspension - Brakes - Steering 2 05-17-2003 08:10 AM
rear sway bar DeathByGreaser Transmission - Rearend 2 02-07-2003 03:25 PM
