clay smith c.304.6.b - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2011, 12:29 PM
hi i need help on my cam i got for 10 buck i just dont now the the lift and what motor will it fit the cam is the clay smith and the c.304.6.b thanks
Old 08-19-2011, 12:36 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
A $10 cam? Make a paperweight out of it.
A GOOGLE search was pretty easy and took about 30 seconds. I found the companys web site on the very front page of the search. c-304-6-b doesn't show up but c-304-8-b does...
It's a big block Chevy cam
http://claysmithcams.com/index.php?r...product_id=190
Old 08-19-2011, 12:44 PM
ya i no the guy did not want the cam any more but the cam say c.304.6.b so i now the c.304.8.b is .615 lift just need to now the lift so i can get new spring
Old 08-19-2011, 01:04 PM
ya the cam is a clay smith the number stamped is c.304.6.b just let nme no is you find the lift on that cam
Old 08-19-2011, 02:24 PM
Wiki Edits: 31
Call them and ask. IIRC George is there expert.. I wouldn't trust a $10 used cam, even tho CS cams are pretty good, and running a cam because it was $10 isn't good because it might not match your engine...
Old 08-19-2011, 03:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cut your losses and buy a cam w/the specs you need, not some crapshoot like this.
If the cam is used it's not worth $10. The chances are very good that it will ruin a new set of lifters and chew itself up in the process, spreading metal all through the engine.
Old 08-19-2011, 06:04 PM
i was in a run truck and he parted the truck out he bout it brand new and payed 180 for it so just call clay smith and they can tell me
Old 08-19-2011, 07:03 PM
Blazin72's Avatar
Wiki Edits: 19
So the guy parted out the engine too? Even though it was apparently running? Seems strange. You can play with your $10 cam if you really want to but you would be wise to just buy a NEW cam and save any potential hassles. You can get NEW cam and lifter sets for right around $100 from Summit Racing.
If the guy you bought it from pulled it out of a running engine shouldn't you already know what engine it was for? If not, maybe you should ask the seller?
Do you even have an engine to put it in?
Either way, it's a $10 lump of iron.
Mel Smith Mel Smith Introduce Yourself 1 05-31-2010 03:06 PM
clay smith cams neverfastenuff Engine 3 11-30-2008 09:43 PM
My Clay Smith cam tommer2 Engine 4 06-03-2008 08:23 PM
Clay Bar jcclark Body - Exterior 9 04-13-2006 07:24 PM
1970 Ford Clay Smith cam mustang Engine 1 09-30-2002 09:14 PM
