clay smith cams - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2008, 08:52 PM
clay smith cams
Has anyone had any experience with clay smith"s high volume fuel pumps? They claim they can provide enough fuel for big HP numbers and they are pretty economical. Thanks for any help.
Old 11-30-2008, 08:58 PM
techinspector1's Avatar
Wiki Edits: 326
What kind of horsepower are you planning?
Old 11-30-2008, 09:11 PM
Nothing radical 485 to 500, my other problem I have is the car is a first gen camaro and the pass. side motor mount is extremely close makes for a tighter package
Old 11-30-2008, 09:43 PM
Wiki Edits: 326
OK, I'm just looking at it from a required fuel delivery standpoint. If the motor requires 0.5 lbs per hp/hr, then at 500 hp, it would require 250 lbs of fuel per hour. Since gasoline weighs 6.216 lbs per gallon, this would compute to the motor requiring 40.2 gallons per hour. Most any pump can provide that much flow.
Here's a muscle car pump from Carter for a big block Gen I...
http://store.summitracing.com/partde...5&autoview=sku
And here's one for a small block....
confused about camshafts (FSB) pstrbrc Engine 9 11-30-2008 08:02 PM
My Clay Smith cam tommer2 Engine 4 06-03-2008 08:23 PM
Comp Cams hydraulic roller vs. solid flat tappet comparison Mad Maggot Engine 23 02-13-2005 10:29 AM
Solid cams vs Hydraulic cams, preference or power? killerformula Engine 17 02-03-2005 09:42 AM
1970 Ford Clay Smith cam mustang Engine 1 09-30-2002 09:14 PM
