i did not intentionally clean the protective coating off the rotors... however i did use some brake cleaner and i swiped both sides on both rotors cause i got a little grease from my hands on them. um. today they didnt feel so hot again.. im def thinking it has osmething to do with my valve now.. so maybe my back brakes arent working tight.
did you check out the other suggestions on your last post? cleaning the protective coating off is standard practise, coating is just to stop suface rust if you didn't clean it off it would burn off.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
