clean out old gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2011, 04:08 PM
what to use to clean old gas tank
Old 04-09-2011, 05:10 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
An old chain and lots of shaking.
Old 04-09-2011, 06:10 PM
poncho62's Avatar
Wiki Edits: 5
I just cleaned 2 small engine tanks using Muriatic acid....It does a good job of removing scale and rust....Only trouble I had was, when I was done I had a bunch of pin holes (rust through)...I had to coat the interior with a gas tank coating product.
Ontario Rodders
Old 05-22-2011, 10:15 PM
I've cleaned out a few vehicle gas tanks and some NATO jerry cans with 50/50 muriatic acid/water and medium sized COARSE limestone gravel. First, I clean out the tank with some Simple Green or other degreaser and wash it out. Then slosh a few gallons of the acid/water mix and gravel and repeat and repeat.
Of course, you want to wear heavy rubber gloves, safety glasses AND a protective face shield, and away from anything you remotely care to keep clean. If you don't have coarse gravel, you can use some heavy chain, but the acid might etch/eat into it a bit.
I then wash the tank out with Acetone and let it air dry. After it's dry, I seal them up with some gas tank sealer.
What would you do with a clean 84 Z28? 6426yy Hotrodding Basics 7 01-10-2008 11:34 AM
clean blackbeard Suspension - Brakes - Steering 1 01-10-2005 07:23 PM
Clean PC johnsongrass1 Hotrodders' Lounge 15 01-03-2005 09:12 AM
One clean I6 Cruiseomatic Hotrodders' Lounge 6 09-13-2004 04:20 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
