Which cleaners for DP90? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2011, 10:26 AM
My '29 has DP90 on it, and all I've used so far to clean it is Glass Plus. Some hot antifreeze/water splattered on the fender and there are some light spots in the DP90. In the past I've been able to get oil & water spots off with the Glass Plus. I'm concerned about using much abrasive as the DP90 starts getting shiny in the areas where it has been rubbed the most - like the bottom of the window frames.
Ideas?
Thanks, Mel
Old 08-29-2011, 10:55 AM
BarryK's Avatar
Just get some ppg 330 wax and grease remover and should clean it right up without hurting the epoxy, After the other items I'm tempted to say re-coat those areas with epoxy to be safe but you might call the PPG tech line or see if the jobber knows anything about it.
Old 08-29-2011, 04:47 PM
Thanks Barry. I'll pick some up and give it a try.
Mel
PPG DP90 Vs. Dupont ?? solidaxel Body - Exterior 5 04-14-2007 12:24 PM
dp90 mikedell1265 Body - Exterior 3 01-17-2005 05:24 AM
new guy...dp90 mikedell1265 Introduce Yourself 1 01-17-2005 12:12 AM
new guy...dp90 mikedell1265 Body - Exterior 2 01-16-2005 07:37 PM
DP90 Prep BT61 Body - Exterior 0 09-14-2003 06:03 PM
