Cleaning adhesive spray gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 12:42 PM
Ok, so I have the DAP Weldwood HHR Contact Cement and a dedicated Harbor Freight spray gun . What's the best solvent to clean the gun after applying the adhesive? I have acetone and mineral spirits-do I need something else? Am I also correct that I can't store the adhesive in the spray gun reservoir for several days between uses?
Thanks.
Old 04-21-2013, 08:51 PM
DanTwoLakes's Avatar
Wiki Edits: 22
This is not like spraying paint, you don't need to clean the spray gun. If you got the right gun, it is an external mix gun where the glue and air are mixed as the glue comes out of the gun. Yes, you can store the glue in the gun for as long as you want to. My spray gun sits for long periods of time, sometimes weeks, and it always sprays as soon as I pull the trigger. My spray gun has never been cleaned, when I run low on adhesive I just fill the cup.
The solvent for the contact adhesive is mineral spirits or Xylol which is just a better grade of mineral spirits. You use the solvent to clean up overspray, not to clean the spray gun. You don't need acetone for anything involving this contact adhesive.
Titan 19220 and Spray Gun Cleaning minibiker2258 Body - Exterior 1 07-24-2011 01:29 PM
Cleaning My Spray Gun liner Body - Exterior 8 03-21-2011 05:25 PM
spray gun cleaning between coats? modas Body - Exterior 1 06-09-2006 11:40 AM
Spray Gun for Adhesive S10Fan Interior 3 07-29-2005 10:00 PM
spray adhesive? nova33 Interior 2 06-15-2003 08:57 PM
