Cleaning Air conditioning system - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 02:28 PM
Pudycat
If a compressor has gone bad and gotten oil in the system what is involved in cleaning up the system? Can it be done at home or is special AC service equipment required? I assume the dryer must be replaced, is this done after the clean up?
Old 08-24-2008, 02:59 PM
Jmark's Avatar
The A/C system has oil running in it along with the freon. If the compressor started shredding metal, then a complete flush of all parts will be in order. You will need to remove the drier and toss it. If you have an orifice tube, pull it too. If you have an expansion valve, remove while flushing. You can use lacquer thinner for flushing. Buy a gallon, it's cheaper that way. You can put about a cup into the condensor and then blow it out with your air compressor. Do this a couple of times. Same with the evap and hoses. It dries FAST and CLEAN. Then install your new drier, new orifice tube or re-install the expansion valve IF It's clean. Replace all o-rings and put in the recommended amount of AC oil. Put on the compressor, evacuate the system and charge.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Heat and Air Conditioning Systems Woody31coupe Interior 5 09-10-2006 06:40 PM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
Making room for gauges, in-dash air conditioning willys36@aol.com Interior 5 04-29-2003 02:24 AM
Trans Am Air System Guitarman General Rodding Tech 1 04-26-2003 09:04 PM
