Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cleaning aluminum heads and SS valves
Old 01-24-2013, 10:21 PM
prostcelica prostcelica is offline
Is it okay to use a Brass crimped wire wheel on a die grinder to clean old gasket material and carbon from the mating surface of aluminum heads.I tried a small area and it looked pretty good. I would also like to clean the carbon from the valves using this method
Please advise
