-   -   cleaning aluminum heads and SS valves (http://www.hotrodders.com/forum/cleaning-aluminum-heads-ss-valves-228809.html)
prostcelica 01-24-2013 10:21 PM
Is it okay to use a Brass crimped wire wheel on a die grinder to clean old gasket material and carbon from the mating surface of aluminum heads.I tried a small area and it looked pretty good. I would also like to clean the carbon from the valves using this method
Please advise
sunsetdart 01-25-2013 04:14 AM
You will much better off using a scotch brite wheel on a disc. The brass will remove old gaskets and carbon but it will alos mar the aluminum.
prostcelica 01-25-2013 07:22 PM
Originally Posted by F-BIRD'88 (Post 1638626)
Do not use either on the decks of an aluminum head. Or you will be milling them to straighten up the mess.
What about the stainless valves? Would the brass wheel be ok for those?
1Gary 01-25-2013 09:18 PM
You too??. I'm still waiting to see the "correct" answer.:rolleyes:
prostcelica 01-26-2013 12:40 AM
Ohh....just wait I'm sure its coming:rolleyes:
