cleaning aluminum heads and SS valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2013, 10:21 PM
Is it okay to use a Brass crimped wire wheel on a die grinder to clean old gasket material and carbon from the mating surface of aluminum heads.I tried a small area and it looked pretty good. I would also like to clean the carbon from the valves using this method
Please advise
Old 01-25-2013, 04:14 AM
Last journal entry: 50 Ply wagon
You will much better off using a scotch brite wheel on a disc. The brass will remove old gaskets and carbon but it will alos mar the aluminum.
Old 01-25-2013, 07:22 PM
Originally Posted by F-BIRD'88 View Post
Do not use either on the decks of an aluminum head. Or you will be milling them to straighten up the mess.
What about the stainless valves? Would the brass wheel be ok for those?
Old 01-25-2013, 09:18 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
You too??. I'm still waiting to see the "correct" answer.
Old 01-26-2013, 12:40 AM
Ohh....just wait I'm sure its coming
Cleaning gummed up valves sexypizzaman Engine 2 11-09-2009 05:53 AM
Cleaning aluminum 302 Z28 General Rodding Tech 8 10-09-2004 08:25 AM
thoughts on cleaning valves 357ford Engine 13 09-10-2004 11:05 AM
Cleaning aluminum heads on a flat head V8 flatheadharold Introduce Yourself 1 07-29-2004 11:01 AM
Cleaning valves babyface Engine 9 06-26-2003 03:49 PM
