cleaning a catalyic converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2012, 05:55 PM
Is it possible to clean a catalytic converter while it is still on the car? I have a ford escape and it's the one on the backside of the engine and I can't get it off.
Old 06-01-2012, 06:01 PM
LATECH's Avatar
NO. Those are notorious for the cores melting down. You probably need a new one.
Fact is stranger than Fiction
Old 06-01-2012, 06:07 PM
66SSImp454's Avatar
Justin
Cleaning a cat is always wishful thinking.
LATECH is right on.
It is not too bad of a job, IRC alternator then axle out then converter/manifold.
Old 06-02-2012, 08:18 AM
bondo's Avatar
LATECH is right on.
Ayuh,... Unless ya consider cleanin' it by drivin' a pipe Through it, 'n knockin' the guts outa it....
It'll be Clean, but it won't pass an inspection test...
Old 06-02-2012, 09:50 AM
delawarebill's Avatar
cat's
my son had a pluged cat on his '05 escape. turned out to be 2 so we replaced all 3... $3000 at dealership... make sure your coil packs are working right... the fronts on his engine were going so he replaced them all...
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
Cleaning up heads. DENCOUCH Engine 1 06-07-2008 07:22 AM
? about block cleaning. bowtieorbust Engine 12 04-25-2004 07:31 AM
350sbc cleaning jrm123180 Engine 9 04-03-2004 07:50 PM
cleaning 78 chevy truck Engine 8 11-26-2003 10:13 PM
