cleaning engine internally - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2007, 05:37 PM
mitmaks's Avatar
Last journal entry: Grille
I need to clean engine internally without taking heads off. Should I use concentrated carb/injector cleaner, anything else?
Old 12-13-2007, 06:15 PM
Jmark's Avatar
"Clean internally" as in the valves, combustion chambers and piston tops.................or the oily innards of the top of the heads and deep inside the engine?
Old 12-13-2007, 06:18 PM
mitmaks's Avatar
Old 12-13-2007, 06:27 PM
Banned
Sea Foam. VERY SLOWLY pour it into your intake while the engine idles, the shut off. Wait a while then start up. you'll see a huge cloud of smoke and then you're clear- not as clear as actually taking the thing apart though.
Old 12-13-2007, 06:29 PM
mike's hotrods's Avatar
I was talking bad about sea foam on another thread, but we talked about it at work today and I hear good things about it, I actually put some in a diesel generator today, half a pint in the fuel and the other half in the oil. I ran the motor for a couple of hours and I did notice a decrease in the puff of smoke that came out when you rev the motor. the stuff smells kind of like rubbing alcohol. time will tell if it helps though.
Old 12-13-2007, 06:30 PM
mitmaks's Avatar
sea foam sounds good except I live in clean neighborhood and Im afraid my neighbors will not be happy about that.
Old 12-13-2007, 06:38 PM
justold's Avatar
What is sea foam and who makes it ? thanks
Old 12-13-2007, 06:44 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
It is used for the purpose stated here. I don't know who makes it, but it is generally on a shelf (near the checkout) in the parts stores around here.
Link to website:
http://www.seafoamsales.com/
They make different products, but the one they are talking about here is the engine treatment.
Old 12-13-2007, 06:47 PM
mitmaks's Avatar
are you supposed to change oil after you use it?
Old 12-13-2007, 07:16 PM
an old timers trick called a "spring tune up", i used to use it in the 70s before doing a tune up on cars with pinging or run-on problems.
while running the engine at 2000-2500 RPMs take a 16-20 oz cup of water and SLOWLY dribble it into the carb while keeping the revs up. the water will go into the cylinders with the fuel/air and will turn to steam upon combustion and steam clean everything and blow it out the exhaust. IT WORKS!!! it's clean and if you have any doubts have a buddy put his hand a foot from the end of the exhaust pipe and and ask him how much carbon came out and hit his hand. when finished let the car idle for five minutes then change out the spark plugs.
edit--i spelled spart plugs.
Old 12-13-2007, 07:31 PM
Jmark's Avatar
A few guys on here recommended it often and I always thought it was a waste,,,,,,,until I tired it. Works great, just follow the directions and you'll be fine.
when I said it smells like rubbing alcohol I ment in the can not the exhaust, I was told to just run it in your fuel and or oil, I'd run it in the oil for about a 1000 miles or so, run it in your fuel every time you fill up for about a 500 miles and then every now and then
Old 12-13-2007, 07:56 PM
I just add a quart of Dextron. When I was servicing repo'd cars for banks, we got a lot of cars in that were so grubby inside the lifters would clatter, It always worked. BTW, Mazdas from the 80s & 90s are very sensitive to that problem, (they will clatter if you look at them sideways) and they respond well too. Dextron is very high in detergent. Better change the oil in a few hundred though...
Old 12-13-2007, 08:17 PM
super_silent's Avatar
I sent an email to the folks at Sea Foam and got a quick, & really detailed reply. Here is what they wrote:
Mike it could be what you say or part of the ring is stuck in the groove due to varnish, at any rate put 4oz of SF-16 in the oil run the unit for 25 KMs and check the oil if dirty change the oil and filter if not dirty do not worry. I would also do the following with the rest of the can. For a gas (not diesel) fuel injected car, warm up the car and make sure
it is outside as there will be a lot of smoke during and after the
application.
With the car running at running temp, lift the hood and take the brake
vacuum line off the brake booster which is located on the fire wall
driver side or take the PCV line out. Pour slowly can of SF-16 down the line this will melt
the varnish that holds the carbon at the back of the intake valves and
top of the pistons, you might have to turn up the RPMs a bit so the
car will not stall.. After can down the line shut the engine off and
put the line back on . Let the unit sit for 15 minutes. Pour
the balance into the gas tank this will lubricate the fuel pump remove
moisture and clean the lines, filter and the injectors. The injectors are not too bad these days.
Now the show! Start the car and find a safe place from
a stop drive the car aggressively you need some load on the engine slow down and stop do
it again the smoke will be gone after 1KM I need the pressure (load) to
get rid of the varnish/carbon.
You will notice a better idle, better fuel economy and more power. Did
you know that Sea foam will stabilize fuel for over 2 years, and works
in all 2,
4 stroke and diesel engines?
Then do your compression test if not a mechanical problem this should bring the compression back to normal on the #7 cyl.
Regards Paul
Old 12-14-2007, 05:59 AM
bondo's Avatar
Ayuh,...... Exactly,......
Why Waste money on Sea-Foam when Water is Free,+ Works Better.......
If I know I'm going to be pulling Heads,...
I'll do a Water cleaning before I start,.....
I run the motor til Warmed, run it up to 1500/2000rpms,+ pour in a 1/2Qt. of Water into the carb throat, Just fast enough to cause the motor to stumble, but not die.......
When the heads come off,......
You'll think you're looking at Brand New Unrun combustion chambers,+ pistons..............
Btw,........
The Spark Plugs will also look Brand New Clean.......
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine Choice, Please Help savman1 Engine 1 01-12-2006 09:36 PM
Injector (out of engine) cleaning advice wanted UncleFluffy Engine 4 10-13-2003 11:54 PM
