Cleaning Floorboards - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2007, 10:18 AM
64Joker's Avatar
64Joker
In the process of interior project, I have my floorboards stripped to the sheet metal. During my stripping, I removed plenty of grime and grease, and in some of the areas a thick black gunk on some corners and joining of metal.
I plan to seal the floorboard with POR 15 (rust preventive), and also install
a sound reducing pad under the carpet.
Question ?
1. Is it necessary to replace this "gunk/tar" sealer, if so, what is it called and
what product is recommended.
Thanks in Advance.....
Old 05-03-2007, 10:42 AM
DanTwoLakes's Avatar
Wiki Edits: 22
If you're going to seal the floorboard and put a sound deadener like Dynamat under the carpet, you don't need to replace the "gunk". Check out the sound deadening and heat reducing products from B-Quiet. www.b-quiet.com.
Old 05-03-2007, 11:00 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That black gunk is a near cousin to roofing tar and does not need to be replaced..Just a miserable task getting it off is all..Use a heat gun to soften it and scrape a lot, then paint thinner to remove the residue and then wax and grease remover before you paint..
The heat gun I use is a turbo version of your wife's hair blower and keep a fire extinguisher handy or a charged water hose ready when doing this..
This question should have been in body exterior..Just an FYI..
Sam
Old 05-03-2007, 01:11 PM
Wiki Edits: 22
Thanks, Sam. I was going to move it until I noticed he mentioned sound deadening material under his carpet. That's why I left it in interior.
Dan
Old 05-04-2007, 05:05 AM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
when i first started my VW under the carpet was this hardened (used to be flexible ) material that was coming out in sheets.. i later found out that they were tar insulation boards.. i promise you they are NOT going back in that car.. ha-ha i had to scrape a lot of it off with a putty knife and a small hammer... to tap it out.. but i wouldn't ever dream of putting it back in
Old 05-04-2007, 07:49 AM
Wiki Edits: 22
Mr Photographer: Sounds like a real mess! Please check your private messages.
Dan
Carburetor Cleaning Solutions leejoy Engine 6 03-19-2006 04:39 PM
Cleaning, boring, painting...383???? Hazard Engine 14 04-14-2005 09:00 PM
Cleaning aluminum 302 Z28 General Rodding Tech 8 10-09-2004 08:25 AM
Block / heads cleaning tips DoubleVision Engine 6 10-25-2002 01:47 PM
