-   -   Cleaning Ford 302 fuel injectors (http://www.hotrodders.com/forum/cleaning-ford-302-fuel-injectors-229462.html)
Torque454 02-11-2013 09:33 PM
I think i have one fuel injector not working. I purchased a pigtail for the injectors, and a 9v battery (found something on google that said to use a 9v battery to activate the injector) and i used my mouth to blow air through (so far) 4 of the 8 injectors. I found one that air would not pass through. I suspect it is clogged since it clicks but wont flow.
How do I clean these injectors? Do they have to go to a shop or can I clean them myself? Any way to test the spray pattern? The air flow trick only tells me that the injector flows, not how well it sprays.
spinn 02-12-2013 12:22 AM
Did the coil winding fail open in the soleniod.
Check the resistance in ohms.
If it needs new injectors get new. I dont buy into the cleaning and rebuilding. They spray fuel . Fuel cleans them.
Silverback 02-12-2013 02:50 PM
Apply power, does it click? do all the coils have the same resistance (older ones should be in the 11-15ohm range)? If they aren't then the coil is open and it needs to be replaced. If it doesn't click the pintle or disk is stuck, without a flowbench and ultrasonic cleaner you're unlikely to get it unstuck.
what works the best is to put them in an ultrasonic cleaner with a mixture of injector cleaner and mineral spirits while pulsing the injectors, then put them on a flow bench and flush the cleaning mixture forwards and backwards while pulsing the injectors.
Oh, you might want to replace the screens in the inlets too. Replacing o-rings and pintle caps is usually a good idea also, they're cheap.
Barring that you might have some luck just soaking them in a similar solution or if the car runs you might get somewhere by putting a good injector cleaner (the chevron stuff is pretty decent) in the gas at 2x the recommended concentration.
crownver 02-12-2013 03:51 PM
If you don't want to have them professionally cleaned, might be worth a shot. You can see what your spray pattern looks like too.
