Cleaning Ford 302 fuel injectors - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 08:33 PM
I think i have one fuel injector not working. I purchased a pigtail for the injectors, and a 9v battery (found something on google that said to use a 9v battery to activate the injector) and i used my mouth to blow air through (so far) 4 of the 8 injectors. I found one that air would not pass through. I suspect it is clogged since it clicks but wont flow.
How do I clean these injectors? Do they have to go to a shop or can I clean them myself? Any way to test the spray pattern? The air flow trick only tells me that the injector flows, not how well it sprays.
Old 02-11-2013, 11:22 PM
spinn's Avatar
Did the coil winding fail open in the soleniod.
Check the resistance in ohms.
If it needs new injectors get new. I dont buy into the cleaning and rebuilding. They spray fuel . Fuel cleans them.
Old 02-12-2013, 01:50 PM
Silverback's Avatar
Boost Retard
Apply power, does it click? do all the coils have the same resistance (older ones should be in the 11-15ohm range)? If they aren't then the coil is open and it needs to be replaced. If it doesn't click the pintle or disk is stuck, without a flowbench and ultrasonic cleaner you're unlikely to get it unstuck.
what works the best is to put them in an ultrasonic cleaner with a mixture of injector cleaner and mineral spirits while pulsing the injectors, then put them on a flow bench and flush the cleaning mixture forwards and backwards while pulsing the injectors.
Oh, you might want to replace the screens in the inlets too. Replacing o-rings and pintle caps is usually a good idea also, they're cheap.
Barring that you might have some luck just soaking them in a similar solution or if the car runs you might get somewhere by putting a good injector cleaner (the chevron stuff is pretty decent) in the gas at 2x the recommended concentration.
Old 02-12-2013, 02:51 PM
If you don't want to have them professionally cleaned,
might be worth a shot. You can see what your spray pattern looks like too.
Cleaning of 1950 Ford Fuel tank Tahunie General Rodding Tech 2 03-10-2012 07:42 PM
high presure fuel pump and fuel injectors ( 300 psi) remcolent Engine 4 08-27-2007 07:36 PM
fuel injected 1992 ford 302 to Carbureted? Young Gun Engine 10 04-13-2007 12:56 AM
Cleaning Injectors on 1992 Eagle Summit Newf69 Engine 2 09-23-2003 08:40 AM
Ford 302 - Carburetion Or Fuel Injection? nightrain_rod Engine 5 08-11-2003 06:07 PM
