cleaning fuel lines and tank without removing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 09:54 PM
0pyders's Avatar
I'm using a rebuilt carburetor and I don't want any sludge and crap getting into it from the old fuel lines and tank. Is there some kind of cleaner I can use to run through the fuel system that breaks down the sludge without removing everything? I just want it to be good enough to not ruin the carb. Car is 25 years old.
Old 04-06-2011, 07:04 AM
boatbob2
cleaning tank.....
where the gas line goes into the carb,disconnect that line,put a hose over that gas line,and the other end of hose into a clear plastic bottle,turn over engine with key,put 2 or 3 inches of gas into bottle,disconnect hose from gas line.look at gas in bottle. if clean (no junk)just change fuel filter,if junk in bottle,go to NAPA and buy a fuel filter and housing,cut gas line just forward of tank,install filter, run engine for awhile,take filter off,and check for junk in fuel,if clean reinstall filter ,youre good to go.if not clean,keep running engine and checking for junk until its clean.after you have clean fuel,change filter.no real need to drop tank.UNLESS its really full of junk.
Old 04-06-2011, 07:13 AM
0pyders's Avatar
Thanks for the advice sir.
Fuel tank cleaning chevelle_502 General Rodding Tech 4 05-23-2011 01:00 AM
Gas Tank Cleaning davlonghauler Hotrodding Basics 5 01-29-2011 03:52 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
Fuel Tank cleaning 65Stanger Engine 2 05-07-2006 04:41 PM
Cleaning a stinky fuel tank RAW General Rodding Tech 10 06-29-2005 10:25 PM
