-   -   cleaning a gas tank (http://www.hotrodders.com/forum/cleaning-gas-tank-117561.html)
Tryin2MakeIt 06-06-2007 08:06 AM
cleaning a gas tank
what is the easiest way to clean a gas tank. i have a truck that has sat and had gas in it for 6 years. that gas stinks and wont burn
boatbob2 06-06-2007 08:49 AM
gas tank cleaning
Hi,i had a gas tank in a boat that was really filthy,very bad gas. i drained the tank,put 1 gal of acetone in it and sloshed it around,did the same 2 more times.then shone a flashlight inside tank,to make sure it was clean. then filled tank with soapy water 3 or 4 times,sloshing it around . then turned tank upside down,drained and flushed tank with clean water. after draining as much water from tank as possible,i left the tank in the sun,with the cap off until it dried. worked great.
home brew 06-06-2007 09:13 AM
The easiest way is to take it to a place that rebuilds radiators and have them put it in their cleaning vat. It will come out sparkling clean. Or you could check out all the suggestions in this thread that I found by typing in "clean gas tank" in the search funtion on this site (link towards the top of the page):
http://www.hotrodders.com/forum/carb...clean+gas+tank
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
bourne51 06-06-2007 09:43 AM
1/2 right!!!
home brew got it half right!......after the boil-out then put a alk.restant plastic sealer inside,(they do it at most rad.shops-for gas tanks),then what i use is a spigit at the bottom,(drain plug),put on the far left or the far right,of the gas tank.after that is done figure out the best way to set up the gas pick up or just use the spigit end and use a cuplink to make a gas outlet.you hook up you gas line from there.i do this because the lowest part of the gas tank is the lower outlet(spigit),make sure before you do the finial hook up you clean and blow out the remaining gas line,and you sperated the line from the gas pump,before you cleaned and blew out the line!!!!!!!!!!!(bourne51)..
gcrmcc 06-06-2007 01:58 PM
If the tank comes out really clean there is no reason to use a poured in tank liner. I would not reccomend using a drain plug with a coupler for the fuel pick up. In reality there should be a gallon or two of fuel that is not usable below the fuel pick up. The sediment in the tank will sit at the bottom. If you make all fuel usable then all the trash that is pumped in at the gas stations will plug up filters and possibly go through the fuel system. also condensation will stay at the bottom and not be picked up if a few gallons are not usable.
gcrmcc
bourne51 06-06-2007 03:08 PM
cool enought!
bourne51 here.......i use two filters on my gas line i have found that sealing a gas tank makes it last a very long time,and i have not had any problems with it and i dont let me fuel run to empty(well not usually),but i will take note on what has been said on this gas tank blog!!!!!!!!!!!!.........
curtis73 06-06-2007 10:52 PM
If its really bad here's what I do. I put a few handfuls of 2B limestone gravel in the tank along with about a quart of acetone. Get you and a buddy to slosh the snot out of it. The acetone dissolves the gunk and the stone gets the stubborn stuff. Don't worry, the stone is big stuff, like the size of the end of your thumb and its not "dirty" -- as in having lots of stone dust and little bits along with it. Its just big stuff so its easy to get out and easy to tell if you've missed one.
I've also had pretty good luck sticking the nozzle of a 3500 psi pressure washer in the filler neck, but since you can't be assured of hitting all the gunky stuff it never inspired much confidence.
bartamos 06-06-2007 11:02 PM
I put clean rags in stuff like that and let them do the cleaning. Slosh it around with whatever fluid you use. It's not hard to fish them out.
techinspector1 06-07-2007 10:30 PM
If the tank is rusty, use the gravel as was mentioned by curtis73 or you can also use a length of chain to slosh around inside.
tattootravis 06-08-2007 02:35 AM
gas tanks and rust
muratic acid in the tank will eat the rust and m.e.k. sovelt [dries it out] after water plume.its cheap and sold at lowes for 5 a gallon,they use it in bleaching pools and sidewalks......does real goood on my motorcycle tanks!
airbrushguy 03-17-2013 10:08 AM
m.e.k. solvent???
tresi 03-17-2013 12:39 PM
I'm not going to argue about poured in sealer being good or bad. I've seen good and bad results. But if you do try it the tank must be totally clean, no short cuts. if not it will come loose inside the tank and you'll never get all back out.
