Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cleaning a gas tank
Old 03-17-2013, 12:39 PM
tresi tresi is offline
I'm not going to argue about poured in sealer being good or bad. I've seen good and bad results. But if you do try it the tank must be totally clean, no short cuts. if not it will come loose inside the tank and you'll never get all back out.
