Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cleaning a gas tank
Old 06-06-2007, 09:43 AM
bourne51 bourne51 is offline
1/2 right!!!
home brew got it half right!......after the boil-out then put a alk.restant plastic sealer inside,(they do it at most rad.shops-for gas tanks),then what i use is a spigit at the bottom,(drain plug),put on the far left or the far right,of the gas tank.after that is done figure out the best way to set up the gas pick up or just use the spigit end and use a cuplink to make a gas hook up you gas line from there.i do this because the lowest part of the gas tank is the lower outlet(spigit),make sure before you do the finial hook up you clean and blow out the remaining gas line,and you sperated the line from the gas pump,before you cleaned and blew out the line!!!!!!!!!!!(bourne51)..
