Cleaning gummed up valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 08:56 PM
Hey guys just a quick question here.......... to clean off all the grime, carbon, and residue caked onto my valves, is it ok to use a bench mounted wire wheel to remove this stuff? I just want to make sure the wire wheel won't damage the valves before I go ahead and use it.
Old 11-09-2009, 12:58 AM
DoubleVision's Avatar
I always used a wire wheel to clean valves also. If oil was gunked up on them I soaked them in seafoam first.
Old 11-09-2009, 05:53 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I have a gallon can of grimmy carburetor cleaner that I use for just such stuff, over night in the can, and parts come out like new...unless they're aluminum. Saves the mess, and breathing in the crap from using a wire wheel...
Just barely started tagging exhaust valves 04SilveradoMykk Engine 10 11-01-2009 10:45 PM
Spring Cleaning For The Members: Tips Only Racing Hotrodders' Lounge 15 03-13-2008 07:02 PM
Unshrouding valves - how much is it worth? Mad Maggot Engine 6 11-17-2004 07:37 PM
thoughts on cleaning valves 357ford Engine 13 09-10-2004 11:05 AM
Question on Aftermarket valves & machining heads unstable Engine 9 05-26-2004 08:50 AM
