Cleaning an Intake - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2007, 09:10 PM
Cleaning an Intake
I have an Edelbrock Performer Intake that is about 8 years old. It has started to turn a dull yellowish color. I am rebuilding my SBC 350, and would like to freshen up the way it looks. Anyone have any suggestions on how to breath new life in to it?
Old 01-28-2007, 09:18 PM
Bead-blast it!
Bead blasting will do the job.
Old 01-28-2007, 09:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Anybody have a good idea what to seal them with after bead blasting?
Old 01-28-2007, 10:18 PM
Eastwood Diamond Clear Satin
This is apecially made to do that job:
http://www.eastwoodco.com/shopping/p...iProductID=619
Old 01-28-2007, 11:07 PM
kuhn-77's Avatar
Build it right the first time
If it were mine I would stick it in a vat, get a chem film on it and then paint it with dupli-color cast aluminum color engine paint, i did the same thing to a holley street dominator intake and it looks amazing, better than it did brand new
Old 01-28-2007, 11:23 PM
powerrodsmike's Avatar
Wiki Edits: 161
I usually put them in the bead blaster (glass beads), blast them clean, then wash it out with soap and water and a bottle brush. Use lots of water. If you use the finer beads (60-80 grit) it won't get all rough.
I have heard of people spraying them with clear to keep them looking good afterwards.
Mikey
BE different....ACT normal.
Old 01-29-2007, 03:13 AM
Guy Hiltz's Avatar
Cleaning an Intake
You could use a lot of elbow grease and polish it,but that is a lot of sanding and polishing.Whatever you do,dont put clear on it ! I did this with mine after I had spent considerable time polishing it and the first time a little hot gas touched it,it turned brown.
Old 01-29-2007, 07:31 AM
Manifold finish
Try Eastwood Diamond Clear. Made especially for this application, good to 300 degrees. They also have Aluma-Blast, a "cast aluminum" finish paint. I have had good luck with this one.
Old 01-29-2007, 08:37 AM
to get back a "new" cast aluminum finish, 10 minutes in a sand blast cabinet
(no need for gentle "media")
the hard way is a scotchbrite pad, brake cleaner and paper towels but that does work to "freshen it" again if it does get stained after blasting
Old 01-29-2007, 09:23 AM
stoney 81ta's Avatar
I used Mag aluminium rim cleaner the one with the corrisive logo on it and several small wire brushes and lots of water.Also wear rubber gloves.
Old 01-29-2007, 12:51 PM
DOUBLEDICK's Avatar
I live were a sand blaster is not available till I buy one.I put mine in the parts cleaner,when it was time to change out my cleaner.I poured the water base parts cleaner on it and let it sit submerged for a few day.When I had time that weekend I pulled it out and it was like new with no scrubing.Now if I start to get a little yellow from anything on it I spray it with chemtool B12 and it comes right off.
Name:	100_1384 (600 x 450).jpg
Old 01-29-2007, 08:52 PM
Thanks
Thanks to all who submitted replies back. I might try the ScotchBrite idea and see how it works. I might also see about powder coating. Any ideas on that? Any idea of ball park on what it would cost to have someone do it?
Thanks,
plthomp
Old 01-29-2007, 08:58 PM
kuhn-77's Avatar
what kind of intake is that that mounts the carb at an angle? thats pretty cool, any performance gain from this?
Old 01-29-2007, 11:01 PM
Another Cleaning Trick
Or clean it in the dishwasher, just time things carefully!
Old 01-30-2007, 10:03 AM
I was going to post "if" there is a powder coat business near by, they do have a sandblaster from hell, and will blast a intake for maybe...$10
every shop that does restoration work will have atleast a "detail" sand blaster....20 minutes max to blast and clean all=$20? + $3 for a bag of filtered sand from HD
pricing general ideas:
sandblast and powder coat a huge mud truck front bumper, $100 at our local powder coat guy (my son's toy)
he blasts and powder coats full car frames for 2/3rds of what it would cost to prep and paint it in the shop
Need Hood Clearance - Intake ? 68chevelle_ss Engine 6 06-30-2005 08:10 PM
QUICK! I have ONE HOUR! Will this Intake work??? Dizturbed One Engine 3 05-14-2005 09:10 PM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 12:12 PM
Dart intake? Brodix or Dart Heads? Slowass72 Engine 3 01-20-2004 04:52 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
