cleaning maf sensor with spray... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 10:58 PM
is the CRC QD contact cleaner good for cleaning the maf sensor's wires? i've read somewhere that that is the best to clean residue without damaging the circuitry.
Old 03-14-2006, 10:06 AM
3m throttle body cleaner 08866
alcohol on a q-tip....tread lightly...these are very delicate wires
Old 03-16-2006, 09:10 PM
what about CRC QD contact cleaner?
Old 03-17-2006, 09:23 AM
should work....don't know if the QD will attack any kind of coating inside the meter.
Old 03-17-2006, 09:45 AM
JamesRS's Avatar
I used CRC contact cleaner on the MAF sensor of my Pontiac Bonneville 3800 several times with no problems.
Temp. Spray Booth didn't work very well fordSR Body - Exterior 10 10-07-2004 05:43 AM
MAF sensor weird problem Pony Engine 5 05-20-2004 08:10 PM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 02:28 PM
Newer GM MAF sensor BlownBirdy Engine 3 02-11-2004 12:04 AM
Block / heads cleaning tips DoubleVision Engine 6 10-25-2002 02:47 PM
